i know you're not planning to use it, but to anyone else considering it: i've used the rattle can version, and i can say 2 things: make sure you spray in a VERY well ventilated area - the fumes are horrible. seemed to be worse than regular paint. also, as brian already said, it doesn't seem to wear well at all, and can only be sprayed in light coats... PITA if you want one thick layer, and the overspray seems to be a waste.
needless to say, i wasn't impressed at all.
