You can program the control without the USB interface. It is achieved by using your transmitter (refer manual).
You can also purchse the USB interface and adapter cable from RC-Monster this is what you will need
1 X MGM Connection Cable 2
1 X MGM usbCom+
You will find them HERE
If you bought the MGM new from RCM it should come with a manual. Best advise is to READ it. It will tell you how to program it. The MGM programing with the transmitter is slightly confusing the first time or 2 you do it, but once you have done it once or twice it makes perfect sense and is very simple to do.
Once you get into it and if something doesn't make sense, shout out again. There are plenty of folks around here that have done this before and should be able to help you figure out specific questions.
to make it...
or break it...
thanx guys for the help.
i ve tryed to programm the esc without succes. Im doing what the manual says:
i turn on the transmitter, with trigger at full throtle i switch on the esc and waits for 10 seconsd to hear three beeps ( right till here) later i need to move the trigger to full brake and wait fro three secons to hear others beeps, but the esc begin beeppin all the time, beep beep beep beep beep beep beep beep beep beep, and doesnt respond to my commandd
any help
thanx and greetings from spain
