MetalMan
MetalMan's Avatar
02.08.2008, 07:21 PM
Does it smell like burnt electronics? Is the voltage cutoff set higher than the voltage of the battery? Have you tried a different radio, or reversing the throttle channel?
02.08.2008, 09:53 PM
Make sure that the connectors between the motor and esc are clean and tight fitting. I have had a variety of issues that were traced back to those connectors.
