New E-maxx tranny
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
New E-maxx tranny - 02.14.2008, 12:08 AM
Is it true that the new tranny won't match up with the mounting holes for the original tranny? Any thing to solve this? I just tried putting the traxxas single motor plate on an original tranny and that doesn't work either, mounting holes are WAY off. Is it possible to make a hybrid tranny? Or should I just get the goriila maxx single plate? I wanted to have the dust cover on as well for a cleaner look, a cleaner chassis, and no rocks or dirt destroying my gears. Any help is appreciated.
neweuser
neweuser's Avatar
02.14.2008, 06:45 PM
For the single plate, it should be a direct fit, are you using the correct half case? You want to use the one without the shifting hole. From my understanding, the new tranny is the same case, just different gears, could be wrong on that though.
Topspeedtimmy
trick mad power (tmp)
Topspeedtimmy's Avatar
02.14.2008, 07:35 PM
Just got the parts for a new E-maxx tranny to build myself off Towerhobbies for $48 without the plate and spur gear for the 'ol revo. A steal! Anyways, The new transmission has a different case, and the gears hav been upgraded to a steel input gear, a steel idler, and finally a plastic output. Yes, I have seen it on another thread that the old transmission mounting pattern hand the holes spaced wide, but the new has 'em space longer and thinner.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.14.2008, 10:21 PM
my half case does have a hole for the shifter but when matching up the 2 plates the holes are way off. Is there any way to adapt the new tranny to the old chassis mounting holes?
neweuser
neweuser's Avatar
02.15.2008, 10:18 AM
Ok, so the solution is use the other half case (one without shifting hole), and use an old style tranny. Still not sure if the mounting holes for the plate will line up with new tranny case or not.
austinmaxx
02.15.2008, 03:48 PM
I got an email from george at gorillamaxx and they are working on gmaxx chassis to work with new e-maxx tranny as we speak...said look for it in early spring
02.15.2008, 08:19 PM
Awesome news... hang on, it is early spring...... :D
