Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
Sammus
Sammus's Avatar
02.19.2008, 07:27 PM
So how much leeway do you have on the rcm chassis? I was looking at some zippy-r packs that area 2200mah 21C and 109mm long. Either that or regular zippy 2100 25C that's 100mm long.
02.19.2008, 08:58 PM
You have plenty of leeway on the battery size. The tray area can accomodate a long battery, but not sure if the included strap can handle the 110 mm long battery. I can measure the strap in a few hours and let you know its length.
Heres a shot of the battery area and strap:
Sammus
Sammus's Avatar
02.19.2008, 10:30 PM
That would be cool thanks.
02.19.2008, 10:41 PM
Ok, using the stock strap, a 105mm long battery will be the max. If you make another strap, or used an old emaxx strap you could fit a 135-140 mm long pack, as the chassis has enough holes to do this. Yo would not be able to put the esc behid the battery with a longer pack. A velcro strap would also be an option, like the gmaxx straps.
