MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
02.28.2008, 12:35 AM
Remember there are 3 different size spur gears available for the savage which are cheaper then pinions. You can use those to change your gear ratio to find the perfect point. I bought a 14t, 16t and 18t pinion (my savage has different diff ratios compared to stock) and with the 3 different spur gears I basically have any gear ratio. I put the FLM kit together last night and I was so impressed. I couldn't believe how well it went together. You won't be disappointed.
