david lamontagn
03.08.2008, 05:44 PM
To enter program mode in the HV110 I left the setting on my radio as is (TH Trim 50/50). After programming was done, I set the trim to -100 and the sub trim to max for brake. You will have to make little adjustments to match the throttle so when you give some throttle it will not have a long neutral range. Just have 2 model open on your radio. One for running the vehicle and one for programming the controller. Make sure brake is disabled on your ESC.
Could you explain me little better please!!! about the trime, 50/50, -100 etc..... This is on trottle trim??
Please explain more in details please!
Thank you very much!
