sikeston34m
sikeston34m's Avatar
03.10.2008, 10:56 PM
Originally Posted by notnodak View Post
I had an endbell come loose and now I need to reattache it, it's a Ammo motor so it screws on but what do I use to lock it in? I want a high temp thread locker. How about Loctite RED or JBWeld?
If you use Red Loctite, chances are you'll never get it off again if you need to. How about the Green Loctite?
The Green is penetrating, plus it's a little more forgiving if you do need to remove it again to replace bearings or whatever.
If the Threads are still in good shape, even Blue Loctite might be enough for what you need. Blue is removeable, but does prevent vibration loosening.
