azjc
03.19.2008, 07:50 PM
Originally Posted by lucias View Post
I am noob to the brushless world and I just wanted to make sure I am understanding something correctly..
A Monster Pro 125 specs are
Continuous - 125amps (@Full throttle, 25deg C
Surge - 300amps (@10 Seconds)
A maxamps 8000mah lipo is
20C Constant(160 amps)
30C Sustained(240 amps)
50C Burst(400 amps)
So you couldn't use this battery with that controller??
Is there a website that goes through the genral brushless guidlines and abreviations?? I have picked up a lot from here but a total noob when it comes to this stuff..
MaxxAmps packs specs should be taking with a grain of salt......
03.19.2008, 09:30 PM
And one of their RMA forms when puffing occures. They should put that on the label!
You will be able to get about 100 amps cont out of that battery. If you are running a 7xl on 4s in a savage, try and keep it light. If you are going over 4s then you will want to go to a 9xl, or a 10xl. I would say that a 9xl on 5s lipo (go with flightpower lipos) and the monster pro. That would be a good setup. You could use the 4900 25c flightpower 5s lipo.
