Problem programming MGM with PC
andy85
Problem programming MGM with PC - 03.25.2008, 08:43 PM
I've just started to use the new pc programming software and problem is its missing things like Residual Energy Voltage, Voltage of BEC, Voltage of battery at switch off. It shows Battery Type, Behaviour when battery voltage going down, Range of neutral zone.....down to --> auto brake in neutral. But nothing else after that. Does anyone have the same problem?
bdebde
That's All Folks!
bdebde's Avatar
03.25.2008, 11:48 PM
There is no Residual Energy Voltage, and no Voltage of BEC. Some of the blank fields like Voltage of battery at switch off only show after a run.
andy85
03.26.2008, 01:12 AM
How do you set the cut off voltage?
wallot
wallot's Avatar
03.26.2008, 04:46 AM
all you specify is number of cells and type of cutoff - power down or slow down
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
bdebde
That's All Folks!
bdebde's Avatar
03.26.2008, 09:43 AM
It is not adjustable, factory set at 3.1v, just select number of cells.
andy85
03.26.2008, 06:05 PM
Damn... Thanks for the input guys.
