What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.26.2008, 05:24 PM
Are you looking for traction control too? You would need a system to compare relative tire speed left to right and compare that to the throttle and steering input. Then all the linkages to control the 4 servos in sync. I can picture exactly what you're going for. Were you going to use the center diff bulk as a front and rear bulk as well? That would make it easier to mount linkages, rather than modifying a normal diff case.
Errr sorry for the semi hijack...
lutach
lutach's Avatar
03.26.2008, 05:38 PM
I was going to use the diff case and make holes to a suitable location for the brake pads and I was actually going to have the brakes pads in the front section of the diff, kind of like in a real car. I was going to try and make the preassure on both sides as equal as possible so that vehicle wouldn't push. If it's anything like my racing kart (Wish I could bring it to the US) it should be easy.
