neweuser
neweuser's Avatar
03.28.2008, 02:33 PM
More power and run cooler? I'm assuming you are looking for more torque. A couple of things you can do without changing motor at all would be to change your gearing. Use a smaller pinion. It may help with heat and power all in one. If you are using a stock radio, try a aftermarket, the response is a ton better than the TX radio it comes with.
Other than that, your best choice would be to use the MM systems for cost effeciency IMO. Go with a 4600 system, or even 5700 would be nice. Unless you are looking to change to something expensive, you can go witha Neu/MM set up as well. Not sure which motor unfortunately.
03.28.2008, 06:39 PM
I would say go to a mega motor, something around 3000kv in the 22/30 series. This motor is more effecient than the traxxas motor and should work well with the vxl speed control.
