04.03.2008, 01:08 AM
do trak power and thunder power batteries use the same balance connector? they both use the v-balance thingy
04.03.2008, 01:10 AM
edit: "thingy" is a often unheard technical term used to describe the subject at hand, I realize with my high school dropout background my terminology is often over the head of the laman, and for that, I apologize
04.03.2008, 01:43 AM
Thanks para, I had actually mistaken it for a whatchmadinky, which I now understand to be entirely different. I wish that I had studied latin, as these technical terms were originaly formulated by canadians. I have alot of trouble understanding people from canadia, which is somewhere near russia from what I hear.
04.03.2008, 01:47 AM
The v balancer has a special harness that plugs into the 2 main 4mm plugs on the trakpower lipo. It also has a a 2mm plug to connect to the balance port. The reg v balancer and the car version are the same save for different colors. Most other flightpower packs have a std balance plug that is the same as thunderpower uses.
http://www3.towerhobbies.com/cgi-bin...&I=LXRWF8&P=ML
Check out the pic, the larger red and black blocks with the male 4mm bullet connectors, also have a female 4mm for the balancer outputs to plug in. The pic shows it already plugged in, but you can buy the adapter seperately, and it will fit a lba balancer with some wiring mods.
BlackedOutREVO
04.03.2008, 01:12 AM
Yes and no
The TrakPower uses 2 4mm bullet plugs, and one 2mm plug in the center
But I think the V balancer does the normal balance plug, or TP style...
On topic, a 7XL in a LST? Isnt a pretty hot motor for a big car?
