Picture Time!!!!
Picture Time!!!! - 04.04.2008, 08:19 PM
Here we go, what you have all been waiting for. Everything is as clean as I care to get it, all bearings cleaned and oiled, and a fresh spur gear. I also installed the double disk brake kit as the old disk looked very worn.
Looking at the nitro motor mount plate, it looks easy to make an electric motor mount. I will use some angle al, and use the slotted holes for the nitro motor to adjust the mesh. I have about 3/8" space between the motor and the tvp with my desired gearing, so I can gear up if needed. I will save the kershaw mount in case I do not like mine, but mine will be much lower cg. It must lower the motor about 1.5-2 inches over the kershaw mount. Wonder why no one else makes simple mounts like this? I am using the smallest spur, 47t, so maybe there would be issues with the 52t? Motor shown is a 14xl, so there is plenty of space length-wise.
Battery trays are from FD, have had them for a while and they work in this application so I will use them. The spacers on the brake side are about twice as thick as I need, so I will cut them in half to bring the tray closer. I had to space that side to clear the tranny casing.
I put the trays up from for weight distribution as the motor and esc will be in the back. Plus they cleared the brake linkage that way, and are up out of the way. I will make some lexan covers for the lipos so they cannot be punctured or damaged.
Just need to wire it up and make the motor mount, this thing may run this weekend, or take 4 months to finish, who knows!
