Electric Dave
04.05.2008, 10:12 AM
Originally Posted by xcntrk View Post
...You must be pulling tons of amps for such short runtime?
Yeah, I've been using one of those mystery Fine Design XLT-1's. I gather they are very inefficient. Once the MMM comes out I plan to switch to a Neu but I'm just not sold on the idea that the motor alone will make that much difference. I only use my truck for racing so it's run quite hard, regardless I'd say 12 minutes maximum is my run time from full charge to a save LVC. If I milk it, I may be able to get to 15 but I've only done it once or twice and I babied it around the track.
DM
crazyjr
crazyjr's Avatar
04.09.2008, 09:33 AM
DM
There is a difference, believe me. I run a 9XL fegaio in a Gmaxx with slipperential and a Neu 1515/2.5d(1700kv) In my G2R. While they compare in speed, thats all they compare in. The efficiency of the neu is so good you will never worry about heat, KV to KV between neu's and fegaio's. The neu is about 2.5 times the price, But i think you get three times the motor with the Neu
