gone
04.10.2008, 02:49 PM
It must be a camera angle, because the motor mount is very strong and large
Like on this pics
04.10.2008, 03:07 PM
Yeah, just looks like a bit of 'fish-eye' type distortion from the camera lens.
Awesome build Gone, should be a serious bit of truck when its completed.
Hardstyle
Hardstyle's Avatar
04.10.2008, 03:25 PM
Yeah, I thought that too.. Gone have you calculated the speeds on that setup http://scriptasylum.com/rc_speed/?
gone
04.11.2008, 11:41 AM
The top Speed will be about 50 mph (80 km/h) on 1st gear and about on 2nd gear 62 mph (99 km/h)
1st gear
Differential Ratio: 26/9
Transmission Ratio: 0.25
Other Ratio: 1
Spur Tooth Count: 43
Pinion Tooth Count: 17
Total Voltage: 22.2
Motor KV: 2300
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 150
Motor coil Ω: 0
Spur/Pinion Ratio: 2.53 : 1
Total Ratio: 16.44118 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 51060 RPM
Vehicle Speed: 53.59 mph (86.08 km/h)
Effective Speed Rate: 2.41 mph/V (3.88 kmh/V)
Estimated Adjusted Speed: 50 mph (80 km/h) - 7% loss
Effective KV Value: 2300
Motor Torque: 0.46 ft-lbs
Final Torque: 7.55 ft-lbs
Final Power: 3330 watts (4.5 HP)
2nd gear
Other Ratio: 1
Spur Tooth Count: 39
Pinion Tooth Count: 21
Total Voltage: 22.2
Motor KV: 2300
Motor coil Ω: 0.01
Spur/Pinion Ratio: 1.86 : 1
Total Ratio: 12.07143 : 1
Total Motor Speed: 47610 RPM
Vehicle Speed: 68.05 mph (109.32 km/h)
Effective Speed Rate: 3.07 mph/V (4.92 kmh/V)
Estimated Adjusted Speed: 62 mph (99 km/h) - 9% loss
Effective KV Value: 2144.59
Final Torque: 5.54 ft-lbs
04.11.2008, 07:37 PM
Wow! I'd expect about 55 max because of the massive amount of drag that truck will have.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.11.2008, 11:30 PM
I'm sure that thing will go faster than 60MPH... 3330 watts is a lot of power...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
jzemaxx
04.12.2008, 12:24 AM
Yeah, my XTM is longer and maybe a little heavier and it has no problems breaking 70mph, except for keeping it on the ground.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
jnev
jnev's Avatar
04.12.2008, 01:21 AM
This is such an awesome project. Great job on the truck gone!! Looking forward to the video(s) and the finished product.
gone
04.12.2008, 06:41 AM
thanks you . Now, I need to a new charger, I would like charge my both lipo 6S 4900mah 25c at the same time, I think to a Hyperion EOS0610i DUO or a power peak infinity 3, but what is the best ?
aqwut
aqwut's Avatar
04.12.2008, 10:13 AM
I would get the hyperion, only $60 more, built in balancer, and 360 Watts.. double the charge output..... I love mine... all of them.. :)
04.12.2008, 10:22 AM
I would say the Hyperion too, though both look rather awesome.
lutach
lutach's Avatar
04.12.2008, 10:24 AM
One guy gave me a little secrete that is working great. What I did is the following: I disassembled my front shocks and added a piece of silicone tube to the shaft and put it back in and that actually stopped my truck from lifting the front end. I also added silicone tubing to the rear shocks (Doesn't need to be disassembled) shaft to stop it from squatting. Now you will have to decide how much up travel you want in the front and make sure all the tubing is the same length. I chose silicone tubing, because it offers some damping, but you can use any other kind of tube you want. I tought it would work, but it does. My truck doesn't lift it's front anymore.
jzemaxx
04.12.2008, 05:20 PM
I have silicone tubing on all 4 shocks already and also a custom wheelie bar. The wind is what is taking the truck....its all of a sudden to. Also its not consistent. Usually around 65-70mph range the truck begins to sway the rear end side to side as lift is created on the rear of the body, then past that it will sometimes just take off....like an airplane with wings. I'm working on reducing frontal area as much as possible and lift. Also I am working on making some bolt on difusers for the rear of the chassis. The MMT is the perfect chassis for high speed runs since its a flat panel. All the other big trucks have an open chassis underneath which creates alot of lift. Also the longer the wheelbase the better I have been with holding the truck down.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
lutach
lutach's Avatar
04.12.2008, 06:21 PM
Do you have tubing inside the front shocks under the piston? I will start doing speed runs again soon and I have my truck sitting a bit lower on the front and I know it will create much more down force, but I know it will stay on the ground. I also have a wheelie bar, but I think it won't be needed. I sure hope Mike can do my chassis soon. With the design I have done, I can use 44.4v and 74v with those long packs from Kong Power, Flight Power and Thunder Power.
jzemaxx
04.12.2008, 07:29 PM
Yes I have the tubing on all of the pistons. Works good. I have also found the other trick is to strap the front suspension with zip ties to not allow the front suspension to unload, essentially making the front end dead weight.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
