Originally Posted by jzemaxx
Yeah, my XTM is longer and maybe a little heavier and it has no problems breaking 70mph, except for keeping it on the ground.
One guy gave me a little secrete that is working great. What I did is the following: I disassembled my front shocks and added a piece of silicone tube to the shaft and put it back in and that actually stopped my truck from lifting the front end. I also added silicone tubing to the rear shocks (Doesn't need to be disassembled) shaft to stop it from squatting. Now you will have to decide how much up travel you want in the front and make sure all the tubing is the same length. I chose silicone tubing, because it offers some damping, but you can use any other kind of tube you want. I tought it would work, but it does. My truck doesn't lift it's front anymore.
