Here is what i did last summer with my Quark 125.... It's very overkill I know, but that thing could handle ANYTHING i threw at it, massive over gearing, you name it.
Brushlessboy16
U should have looked at my thread PedeBeater, these guys said the exact same thing....
anyways here is my capacitor board
It is not bad, but to achieve the goal -> there should be no connectors on the path from caps to ESC and wires should be as short as possible.
Like Zeropointbug, but with less caps :)
[QUOTE=GriffinRU;164735
Like Zeropointbug, but with less caps :)[/QUOTE]
Yes, exactly... maybe 4 of those caps, at the very most; anymore and you're not benefiting.
i know about the connectors, but i dont know if i need it or not, so im going to test it-make it removable for comparison..... If it works out well ill solder it in
