bdebde
That's All Folks!
bdebde's Avatar
04.22.2008, 08:34 PM
Got .NET installed? Need to install as admin, and may need to run in compatability mode.
bribeguy
04.22.2008, 10:41 PM
To be honest, I have no clue.
azjc
04.23.2008, 02:51 AM
I have Vista 32 and I installed Castlelink as an administrator, I dont know if 64 is any different, there were instructions on the CC website
azjc
04.23.2008, 03:17 AM
copied directly from CCs website
4. What are the system requirements for the Castle Link to work on a PC? Does it work with Vista?
Castle Link will work on almost any PC running Windows 98 SE through XP. It will not run on Windows 95 or earlier.
Castle Link is not officially supported on Windows Vista at this time, however, some customers have reported getting it to work by using the following method. For those using Windows Vista (32bit only, 64bit will not work), rather than hitting "run" and downloading/running the software, save the install file to your desktop. Right click on the install file that is on the desktop and choose "run as administrator". The Castle Link software should install properly after that.
