t-maxxracer32
t-maxxracer32's Avatar
04.27.2008, 06:34 AM
the way i see it is that when you power on the mamba max even though you are not doing any running there is still power going through the esc in the board which would cause it to generate SOME heat.
correct me if im completely wrong on that
try using a ubec and see if that will make any difference.
when you say "is it ok for the esc" do you mean is 120 degrees ok? or running through the grass ok?
both those scenarios are fine.
you are pushing the little guy alot so expect high temps --- more volts than intended... neu... heavier truck than normal... your mm esc is getting a nice workout.
also if you have the money then heck ya go for the monster!
Gallagher
04.27.2008, 07:10 AM
I am using UBEC with my mamba max esc and heat is generated in this situation.
This is what I forgot to mention.
I have not noticed this in other escs.
lutach
lutach's Avatar
04.27.2008, 10:30 AM
Did you remove the red wire from the controllers receiver plug? I had an issue like that a long time ago with another controller. I like to use RX packs and I noticed the same thing. Then I removed a jumper that disables the BEC and it solved the problem.
