B4maz
05.02.2008, 03:26 PM
Hmm. I just got off the phone with Castle Tech support and they said there was no way to set the radio or ESC up to do this without the pistix. I didn't feel like arguing that it HAS been done so I just thanked him and moved on. I will definitely try the fixed point setting now (did not see the post before I called).
BTW: In case anyone is wondering, pistix is apparently pronounced "pie-sticks". I was saying "piss-sticks", lol. Foiled again by inconsistent English grammar! :dramatically shakes fists at sky:
You can definitely do without the pistix. It might help using it, but once I changed the HV settings to fixed endpoint, all I had to do was adjust the throttle EPA and trim until i got the HV-110 to arm. The only problem is that I have to hold brake to keep the motor from running. If i have the trigger in neutral position, the motor will run slowly. Its just an annoyance and I should fix it, but it works just fine.
lutach
lutach's Avatar
05.02.2008, 03:51 PM
That's what I did as well and to program the radio, I used to switch to another model memory with everything at defualt and I could get into program mode fine.
