lutach
lutach's Avatar
05.03.2008, 07:17 PM
Believe me, I am looking at doing an 8S or 12S version (or both) of the MMM --
My question is:
Would people be willing to spend an extre $120.00 on a 12S MMM? That's really the minimum extra it would cost to do a 12S controller...
Also, a 12S system would more than likely be Opto, to keep the motor noise from the radio. So would require an external power source for the RX/Servos.
An 8S system would certainly be easier, but still a little more costly than the 6S system.
Patrick
I guess the extra $120 will be because of the controller being completely different from the 6S right? I can work with Opto as most of my HV controlelrs are Opto. I'm in for 4 maybe more 12S units as I can use 8S and 6S as well with it.
Off topic: Can a simple forward/brake software be made for the SHV if the hardware is not compatible with the Mamba software?
Pdelcast
Pdelcast's Avatar
05.03.2008, 07:22 PM
The difference in cost is because of the difference in number and price of the MOSFETs. Double FETs with higher price for a 12S system. Remember, MOSFET resistance goes up by the square of the voltage.
There probably won't be any forward/reverse SHV software made available. It just doesn't have the hardware for braking/starting heavy loads.
Patrick
Pdelcast
Pdelcast's Avatar
05.03.2008, 07:24 PM
BTW, I'm in China now, checking progress on the Neu/Castle motor assembly line design. Pretty close to building motors. If I get a chance, I'll post some pics.
Patrick
lutach
lutach's Avatar
05.03.2008, 07:40 PM
Patrick
I called you on Friday, then I remembered you told us you will be there until the 8th. I sent you an e-mail, but I'm not sure you received. Would you be able to do motors for customers specs and designs?
lutach
lutach's Avatar
05.03.2008, 07:38 PM
Patrick
That sounds good. Count me in for 4 or more 12S Monster Max. All I'm asking for the SHV is forward/brake. I'm not going to be putting a high load on it, but what is the highest available AMP rating the small versions (Not the big 250A one ) have?
