Pdelcast
Pdelcast's Avatar
05.03.2008, 07:22 PM
I guess the extra $120 will be because of the controller being completely different from the 6S right? I can work with Opto as most of my HV controlelrs are Opto. I'm in for 4 maybe more 12S units as I can use 8S and 6S as well with it.
Off topic: Can a simple forward/brake software be made for the SHV if the hardware is not compatible with the Mamba software?
The difference in cost is because of the difference in number and price of the MOSFETs. Double FETs with higher price for a 12S system. Remember, MOSFET resistance goes up by the square of the voltage.
There probably won't be any forward/reverse SHV software made available. It just doesn't have the hardware for braking/starting heavy loads.
Patrick
Pdelcast
Pdelcast's Avatar
05.03.2008, 07:24 PM
BTW, I'm in China now, checking progress on the Neu/Castle motor assembly line design. Pretty close to building motors. If I get a chance, I'll post some pics.
Patrick
lutach
lutach's Avatar
05.03.2008, 07:40 PM
Patrick
I called you on Friday, then I remembered you told us you will be there until the 8th. I sent you an e-mail, but I'm not sure you received. Would you be able to do motors for customers specs and designs?
lutach
lutach's Avatar
05.03.2008, 07:38 PM
Patrick
That sounds good. Count me in for 4 or more 12S Monster Max. All I'm asking for the SHV is forward/brake. I'm not going to be putting a high load on it, but what is the highest available AMP rating the small versions (Not the big 250A one ) have?
