azjc
05.04.2008, 01:17 AM
Originally Posted by big greg View Post
well the guy is selling this one on rctech, would this do good in my revo? i got an 8xl i could do in the buggy, buy how would this fare in the revo, with mm on 4s?
are you refering to the 1515/2.5d that motor would be a bit slow with 4s I am going to run that in mine with 6s, it has a kv value of 1650, in your revo I would either run a 1515/1y(2200 KV) or a if you want more speed the 1515/1.5d (2700kv). The 1.5d it is rated @120 amps which is approaching the limit of the advertised limit of the MM, since the 1.5d is a faster motor it will pull more amps than the 1y and you will have a slightly reduced run time probubly about a total of 15mins
