Is it possible to use the Tekno chassis, and servo mounts, battery tray and all that (except for the motor mount) and use the RC-Monster mount so I don't have to use the clutch? Also, will the battery tray fit the stock chassis? Will the mud guards fit the stock chassis?
Thanks in advance for any answers.
Mike will be able to confirm if the RCM mount will work once the kits are available. Just looking at it, it looks like there shouldn't be an issue. You may have to remove the rear brake assembly, but not 100% sure. The kit includes a complete clutch setup so you'll have it to try out either way.
The battery tray was meant to fit our chassis specifically. However, it could be used on other chassis' if you space it up 2mm off the chassis for the straps to clear. As it is now, the chassis is cutout underneath the battery tray to make room for the straps. Our chassis is actually lighter than the stock chassis by .5oz despite it having a bigger overall footprint. The truggy chassis is over 1oz lighter than stock :)
well for some reason i called to check on when the motors would be available and they had one of the motors i needed left in stock, 1515 1y/f tekno edition,(last one)
so i have one on the way, cant wait to run my truggy with a good motor
i will let you all know how it runs
and i want to say thanks to whoever it was at tekno that i talked to tonight
i hope to be running this this weekend, jk
Be sure to report back to us on how the motor goes
