What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.08.2008, 05:53 PM
Originally Posted by tc3_racer_001 View Post
W_N, what is TEC/WB stand for? its sick, looks much better than in those other photos ive seen, cant wait!!
Originally Posted by sleebus.jones View Post
I'm gonna go with ThermoElectric Cooler/Water Block.
Not sure why you'd want to? Air cooling is much more efficient in this application.
TEC = power hog. TEC's are great if cooling something below ambient improves performance.
Water block needs water, pump, radiator, which will use more power and add a hell of a lot of weight.
Correct. It would be more for show than go, I just think TEC's are really cool! You'd only need to run about 50-70W through it to keep it nice and chilly. That kind of power is nothing compared to the power that would go through the ESC at ultra-low temperatures. I only suggested the idea because of the single FET board, which makes it possible.
Pdelcast
Pdelcast's Avatar
05.08.2008, 05:55 PM
WE DO NOT recommend attempting to remove the MMM heat sink. It would be difficult to do so without damaging the FETs. (besides, removing the heat sink will void your warranty. )
Patrick
