JOEX
05.19.2008, 11:56 AM
That's the idea If I do have one of the bad ones just want to make sure this set up will work
bl-is-future
bl-is-future's Avatar
05.19.2008, 12:00 PM
Not sure if them Titans can take 4s. I put a 3s on a e-savage with jsut the MM and i smoked both of the motors in that.
JOEX
05.19.2008, 12:02 PM
That's why i'm using the $3.50 knock offs
bl-is-future
05.19.2008, 12:06 PM
in that case hook it up and go for it. They say if the MMM is going to fail it will fail in the first 10 min of running it. I have ran over 3 cycles through my MMM and has not had a problem.
You proly know this but make sure you set the ESC to brushed mode.
Also remember to set it back to Brushless when you put the brushless motor in.
I forgot to set a MM back to brushless once and i cooked it!
JOEX
05.19.2008, 12:11 PM
Ouch!
Can you remind me again when I get a brushless motor
bl-is-future
05.19.2008, 12:12 PM
Ouch!
Just make sure you post when you get a BL motor and i will try to remember to remind you!
05.19.2008, 12:29 PM
I am sure the titans can handle 4s, they are 23turn 550 motors.
