bl-is-future
bl-is-future's Avatar
05.21.2008, 09:26 AM
Okay i think i got it. I took the tranny apart and took of the 1st and 3rd gear. I took the 2nd gear clutch and took the grub screw out that adjust the clutch sensitivity. I then held the clutch open and soldered it. I then put the clutch back in the gear and soldered it all the way around and held it to the gear. So far it has worked great. If it doesn't hold i will tact weld the clutch to the gear. Problem i have now though is my motor is very hot after a run. But just the motor. According to the rule of thumb i am under geared. But i am already at 16/47. I know the motor will run hotter because of the motor brakes but i am just worried about smoking the motor. I will have to get exact temps, just have to find my telemetry for my nomadio.
