rootar
rootar's Avatar
05.22.2008, 09:37 AM
yes it uses hub exteneders and buggy arms, i did disassemble the extenders the other day to see how they were built because they have zero slack in anydirection which is odd for a hub extension cause they usually have a little tiny bit of play no matter what, and i learned im not tkaing these off unless i have too they are a PITA and fit extremely tight, i guess the wheel bearings will wear out a little faster due to the extra leverage on them but i doubt ill have any problems out of the extenders.
besides i could always yank the wheel extenders off, throw some buggy tires on there and the wing and mounts from a strom and id have a 1/8 scale buggy with a 13.75 inch wheelbase lol thatd be one good handling buggy.
rootar
rootar's Avatar
05.22.2008, 06:00 PM
here is the front part of the motor mount and the esc mount, the back part of the motor mount istn pictured because it will bolt to mike heatsink clamp when ever i can get one. (motor mount is made out of .100 7075 t6, while the esc mount is .050 6061 t4)
the esc mount plat has a flat part 2x3" and should be big enough to hold the mamba monster and a CC bec and the on off switch.
btw all this bolted to existing holes inthe chassis, and so will mikes battery tray, so its been alot easier then drilling and taping a bunch of holes like i did on the Ls10
what do yall think?
ID:	4675   Click image for larger version
rootar
rootar's Avatar
05.27.2008, 06:59 PM
little up date,
i recieved the 5s flightpower pack from tallyram and the hitec servo from jnev today, i also painted the esc and motor mounts black to match mikes battery tray and black XL heatsink itll be using. so hopefully itll be a pretty clean looking install with it all done to match.
the tmaxx reciver box (from blrevo) and my order from mike should be here this week also and after that itll just be waiting on the revised MMM to get started shipping
rootar
rootar's Avatar
06.02.2008, 11:16 PM
finished it up today,
got mikes battery tray mounted, the flightpower fits PERFECT, i dremeled out a small channel where its next to the spur and its as close to the middle as possible.
ID:	4737   Click image for larger version
ID:	4738   Click image for larger version
rootar
rootar's Avatar
06.02.2008, 11:34 PM
here is the cradle motor mount i changed my desigin so that the rc-monster heatsink / cradle sits all the way down on the chassis, its also clamped and supported in the rear and i still have to paint the rear support black to match everything else.
very solid
also im glad the 10xl came in black to go along with everything else i was dreading having a purple motor stick out like a sorethumb, guess i got lucky or is that a thank you mike?
ID:	4740   Click image for larger version
rootar
rootar's Avatar
06.02.2008, 11:52 PM
hahaha you wont get to see this baby go off the ramp, the LS10 is gearing up for a record attempt jump but thats another subject, im building this truck to RACE and spank some nitro ass.
as for the motor mount read above a few post and youll find it
Here she is all finished up, as is with the big honkin MT tires, and no esc im at 9.1 pounds, is that heavy or light? or normal for a 5s setup? im geared 14/54 and once i drop the extra weight of the mt treads for some LPRs or komodo LPs ill have it geard for about 37ish with a 6% loss.
you can also see the tmaxx reciver box in the photo (thanks bl-revo)
i think it turned out good and clean now just gotta paint that back half of the motor mount to match and get an ESC.
plans with the low gearing is for 25 min runtimes and cooler esc, hopefully itll be under 9 pounds rtr with the MUCH lighter tires and the esc installed, oh and i gotta put my wing mounts and wing on off the storm buggy when they come in.
well howd i do for my first "nice" build ?
Dafni
Dafni's Avatar
06.03.2008, 03:52 AM
Nice, but you should not use the motor as chassis brace.
Your chassis will flex, and with the motor like that, you' re asking for trouble.
Daf
