azjc
05.25.2008, 01:48 PM
Originally Posted by pb4ugo View Post
Yes. I think the difference in effeciency between a 10s1p setup and 5s2p at this point would be minimal. 5s controllers can be had a lot cheaper and with US support than 10s controllers. Mind you I insist on controller brakes.
than you will have no increase in power you will double the capicity, unless your goal is to be able to run twice as long without changing packs you will have a lot of extra weight with no increase in power and that will increase your power usage
just my .02
pb4ugo
05.25.2008, 02:05 PM
But the motor drawing 150 amps on 5s (slightly under 15c) will put out the same power as the motor drawing 75 amps on 10s (same load on batteries).
I know there are minor benefits to be gained in efficiency (and therefore power) in the 10s situation. It just doesn't pencil out for me as being worth the money. Most of us need to figure out ways to control all the power we have anyways.
