azjc
05.27.2008, 07:00 PM
if you want to go more than 6s I would run dual packs than and buy the 0610 duo, which has 2 sets of output jack and balancers. The 1210 charger based on the 180 watt number and allowing 20% for effiencicy you still could only charge a 6s @ 6 amps and this is the max you could do and as you go up in cells it will get worse, when I was looking for a charger the max wattage the 1210 could do scared me away from it more than not having a balancer
tc3_racer_001
tc3_racer_001's Avatar
05.28.2008, 07:49 AM
i cant decide between the 0610i ($158 delivered here): http://www.hobbycity.com/hobbycity/s...rger&cda=17832)
and the icharger 106B (http://www.hobbycity.com/hobbycity/s...rger&cda=17832)
the balancer is highly accurate, but has no firmware updates and customer service is better than ive ever seen anywhere)
which is $95 delivered.
from the reviews, its over 93% efficient which is awesome... ive got a watt meter coming so i will test which ever charger i end up getting...
saving $60 is pretty good, for a charger which will only be used for charging 4s a123 @ 10A... which both can do. even if i do get a 5s lipo (which wont really ever happen anyway) i would only charge it at 1C
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
