MetalMan
MetalMan's Avatar
05.31.2008, 10:02 PM
Originally Posted by sleebus.jones View Post
Then it might fail from overheating, unless you put a different fan on it. FWIW, my fan failed, the monster is still going strong. I'm not running it tho, due to the fact I don't have another fan to stick on it at the moment.
That is a possibility, but at least for my setup a MM was used previously with no fan, only four 330uF low-ESR caps, and in my 1/8 buggy the MM didn't go above 140 F. The MMM even without fan shouldn't reach anything beyond 110 F, I think.
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
06.01.2008, 10:57 AM
Not what this person reports here:
http://www.rc-monster.com/forum/show...22&postcount=2
I don't think I'd run the monster without a fan, especially down here in Texas. It's been silly hot here lately, no wind, high humidity, etc. Not much temperature differential to cool an ESC. Active cooling is a must I think for larger vehicles. With a fan, you can run without worries, without one you'd probably be checking pretty often.
I vote for the "no worries" option.
MetalMan
MetalMan's Avatar
06.02.2008, 01:15 AM
My bad, I meant in my setup it shouldn't go beyond 110 F.
