VintageMA
VintageMA's Avatar
06.02.2008, 05:04 PM
Originally Posted by Sower View Post
I don't get it . . . changing the voltage drastically changes all the characteristics of the system. I think most people set up a system with an end use in mind and stick with it. Why are you changing the voltage for your systems?
Generally I agree, but I can think of two scenarios:
1) HV - the more cells you use, the less of a difference a change makes. If you are using 2 cells, then yes going to 3 is 50% more speed. But if you are using 5 then going to 6 is only a 20% change. I have a setup that is going to be a nice powerful ride on 6S geared for ~42-44, but will want to drop down to 5S for some calmer driving around.
2) Doesn't apply to me, but if you have an ESC you want to switch between rc's with different setup it would make things a little easier than having to reprogram every time.
“Everyone has a right to be stupid; some people just abuse the privilege.”
Sower
Sower's Avatar
06.02.2008, 05:10 PM
I see. I guess I've always been trying to nail my setup for a very specific use and only that use so I've never looked at it that way. Interesting.
When I started building my current system I knew I wanted 6s HV, low amps and it's working awesome. This weekend I was getting 25 minutes of runtime at the track going full out in my XT8. Motor temp never broke 100.
MBX6T Tekin RX8 5s Neuenergy
www.robsower.com
