Duster_360
06.04.2008, 01:11 PM
Originally Posted by Sammus View Post
Instead of monitoring them with a temp gun you could get the probe that plugs into the hyperion.. that way you dont have to stand there to monitor them, it will cutoff itself if it gets too hot.
I just got mine and I'm hoping it does not have the horrible lag that the temp probe for the Ice charger has. The hyperion probe should have a better thermal "connection" to a batt and that should help minimize the time lag between real temp and tem the probe indicates. That time lag with the Ice charger would let you overheatl a batt unless you adjusted the limiting probe based temp down by 20 or more degrees. Hope this one is better.
