06.05.2008, 12:14 PM
That's a good combo;
- if it actully works
- if the motor hasn't been abused
- if you never plan on running more than a 2 pole motor (BK ESCs don't run anything else)
- if you don't mind just about nonexistant support should something go wrong
- if you don't mind a lack of any programming options in the ESC.
- if you don't mind a lack of LVC for lipos. Either run NiMH only or use an external LVC.
Aside from that, the BKs worked well. Pretty much a plug and play system. Oh, and I'd pick up Mike's motor clamp/heatsink to make sure the motor doesn't come apart.
