GriffinRU
06.07.2008, 09:21 PM
Sure. We could even change the caps and add the TVS for you.
Fantastic! That what I was looking for. Can you add copper plate? And 5-6S support?
Pdelcast
Pdelcast's Avatar
06.07.2008, 09:31 PM
You do know that the copper plate and the Artic silver doesn't really make much difference right? What would make a big difference is to go to a pin-fin copper heat sink... like this one:
http://www.coolinnovations.com/produ...UltraCool4.php
Patrick del Castillo
President, Principle Engineer
GriffinRU
06.07.2008, 09:43 PM
Try to take an infrared picture of your ESC with and without copper plate, I do not really care about arctic silver...as long as you can keep it as flat as possible, you can use graphite if you can maintain below 0.005". You know there is a step with sand paper right, not only for adhesion.
Sure, there are even better things you can do. If your R&D budget can afford 2 month clean-room run, I can share with you what can be better and we can talk patenting...
Pdelcast
Pdelcast's Avatar
06.07.2008, 09:58 PM
I have IR pictures of the ESC, and a copper plate doesn't make any significant difference on the 6oz board... the older 4oz board was a different story. And, a copper pin fin heatsink is actually an easier mod will have much more effect than a copper heat spreader.
BTW -- we are using the temp sensor on the processor -- so make sure any mods you do reduce the temp difference between the FETs and the processor, not the opposite.
What does that mean -- 2 month clean-room run? Are you thinking about getting On Semiconductor to give us some Fab time, or what?
GriffinRU
06.07.2008, 10:20 PM
Well, true for the last gen. pcb with only 6 fet's down there... still can see slight improvement. If you plan to add copper heatsink to MM, than I am sorry who needs MMM in 1/8 scale? You can do the same to MMM, of course. Just get plated copper, so it doesn't change its appeal :)
I know, on first versions I was adding copper spacer, but lately reusing your foam, works alright. :)
Something like that, but not at On Semiconductor, more like proto run at University and upon success, I do not know it is way too early.
Pdelcast
Pdelcast's Avatar
06.07.2008, 11:28 PM
Well, the main problem we had with all of our Copper heatsink testing was that the heatsink is HEAVY -- and on crashes would sometimes rip the FETs off the board (or in half!)
The copper heat sinks did work very well, but were very expensive.
On Semiconductor has done some custom stuff for us in the past -- they might be willing to listen.
GriffinRU
06.07.2008, 11:40 PM
There are ways to solve this, fet's case cannot support such load. Expensive way - hybrid heatsinks, all the way up to built-in heatpipes. Second one - pcb support for heatsink, you can solder heatsink to the board.
Well, now that is when we switch to PM.
By the way, I am pretty sure, you've seen that :)
06.09.2008, 01:57 PM
Is this a potential option for a more expensive MMM that doesn't need a fan? :)
Cheers
