Pdelcast
Pdelcast's Avatar
06.07.2008, 11:28 PM
Originally Posted by GriffinRU View Post
Well, true for the last gen. pcb with only 6 fet's down there... still can see slight improvement. If you plan to add copper heatsink to MM, than I am sorry who needs MMM in 1/8 scale? You can do the same to MMM, of course. Just get plated copper, so it doesn't change its appeal :)
I know, on first versions I was adding copper spacer, but lately reusing your foam, works alright. :)
Something like that, but not at On Semiconductor, more like proto run at University and upon success, I do not know it is way too early.
Well, the main problem we had with all of our Copper heatsink testing was that the heatsink is HEAVY -- and on crashes would sometimes rip the FETs off the board (or in half!)
The copper heat sinks did work very well, but were very expensive.
On Semiconductor has done some custom stuff for us in the past -- they might be willing to listen.
Patrick del Castillo
President, Principle Engineer
