83gt
06.09.2008, 01:31 PM
I don't care what anyone says, the TrueRC packs perform better than a higher rated maxamps pack. Less voltage drop, less heat created, more punch, better runtimes. What more do you want ? This is comparing maxamps 4s1p 5000mAh 20C to TrueRC 4s2p 8000mAh 10c.
Now maxamps says "hey wait! you can't compare a 5000mAh to an 8000mAh!!!" I say I can, especially if the 8000 is cheaper, and has a lower overall amp rating. If the maxamps is rated at 100A continuous, and the TrueRC is rated at 80A continuous, then at 75A the maxamps SHOULD have less voltage drop, and less heat created. However, this does not seem to be the case.
Go with the TrueRC. Choose a pack that will be right for your amp draw, and you will not be disappointed.
06.09.2008, 01:58 PM
Agree 100%. But just remember, battery ratings are all over the place, and are no way to compare lipos. You must buy from the mfg who has the best advertising, they have the best products.
That last part was pure satire, but I think that is the basis for most arguments. Especially if you read the NK forum, people their claim that MA is the best, yet have never tried any other mfg lipo?!?!?
