Originally Posted by lincpimp
So you basically compared two cheap chinese cells, a 3800 and a 3000 (in 2p config to make the 6000). There is a huge difference between a maxamps 6000 and a trakpower (4900mah). Batteries make a huge difference. My 7xl vehicles would not run correctly with maxmaps 4s pack, 5000 or 6000. They run fine with a pair of trakpower lipos. And the trakpower was cheaper than the 6000 packs.
I compared a cheap 4S 3800mAh pack AGAINST a Maxamps 4S 6000mAh, so, you're saying Maxamps are crap too?
Problem with those other packs is the dimensions won't fit my truck (BLST), but, they will in the CRT & Kanai. I wanted to keep them all the same to make it cheaper, but, looks like I will have to go the really expensive stuff.
On that note, where can I get these packs nice & cheap??
