06.12.2008, 09:50 AM
Originally Posted by Mozzy View Post
I don't believe that the brand of cells makes that much of a difference, as I have tried both a cheap chinese 3800mAh 20C 4S & a Maxamps 6000mAh 20C 4S, back to back, & the only difference was very slightly lower on initial punch with the 3800 (due to available amps.) & run time was longer with the 6000 (obviously). Top speed was the same in a converted Revo with stock gearing & a X1-CRT with stock gearing.
So, I don't see what could've been wrong with you batts to make that much of a difference.
Either way, they're still faster than nitro!!!
So you basically compared two cheap chinese cells, a 3800 and a 3000 (in 2p config to make the 6000). There is a huge difference between a maxamps 6000 and a trakpower (4900mah). Batteries make a huge difference. My 7xl vehicles would not run correctly with maxmaps 4s pack, 5000 or 6000. They run fine with a pair of trakpower lipos. And the trakpower was cheaper than the 6000 packs.
