Daddydancool
07.03.2008, 08:38 PM
Man i hate you!!! now i need to do this since it's really a nice clean way to fix the batt, you just used foam that you glued there on the aluminium tray that you made? did you just used a normal alu sheet to do it?
Thanks a lot for you help!
You could make your own custom tray, something like this:
entjoles
07.03.2008, 09:05 PM
mike made me a longer one, and i just used spacers and longer screws to make the posts taller, you can contact him and give him a measurement , this is a 5k 3s maxamps pack btw..
Daddydancool
07.03.2008, 09:50 PM
this set up is nice too, but the one of the previous post seems to work better, the batt can't get out of the frame this way!
if i'm not able to make one, i will just make a longer strap and use spacer,
Thanks!
07.04.2008, 12:39 PM
The foam is just some adhesive-backed craft foam from the craft section at Wal-Mart. Comes in a 8.5 x 11 x ~1/16". Just cut, peel, and stick. Cheap too.
The metal is ~1.5mm thick 6061-T6 from onlinemetals.com cut and bent into shape.
Shark413
Shark413's Avatar
07.04.2008, 05:01 PM
Here is my setup, it can handle really long lipo's and it uses the exisiting motor mount holes so you don't need to drill holes in the chassis. It is basically a flat plate with a small aluminum bar stock bolted to it, and this piece bolts to the chassis. the battery is held with a combination of velcro and a strap. The plate is very rigid and keeps the battery from hitting the spur.
Just make the plate as long as you need for the length of the battery your using.
Flat aluminum plate bolted to a small aluminum bar.
Updated version using carbon fiber instead of aluminum.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
