azjc
07.05.2008, 10:03 AM
Originally Posted by e-mike View Post
right....my top speed is lower with my 1515 1y vs the 6xl but wowothe max temp that i reach is 114f(compared to my death feigao 6xl 290f) for 20 min of street bashing....
you have a 1515/1 and a MMM I would go up to a 5s pack and if that is not enough you could go to 6s...you can wire a 3s pack that is idenical to one of your 2s packs in series to form a 5s pack..."You need more power"...when you go higher kv the motor becomes more amp hungry and that will cause heat
e-mike
e-mike's Avatar
07.05.2008, 09:19 PM
your right....i never think about plug one 11,1 volt with a 7,4......i never think that it was possibleyou give me a good solution!!!
azjc
07.05.2008, 09:29 PM
just make sure it is the same capacity, and I would go with the same brand since your chances that they would be the same cells would be better
e-mike
e-mike's Avatar
07.05.2008, 09:33 PM
this is what i tinkingbut now i have a 1515 1,5d to come...can i run this motor on 5cell ??? or keep 4 cell...i would 45mph im geared 20/68...
azjc
07.05.2008, 09:57 PM
I think 4s will be plenty for a 1.5d but it will eat more amps causing more heat, be sure your timing for the ESC is at the lowest setting, and I went back looking at your first post and it looks like the truck you have is an E Revo if it is the biggest 8000 size you could fit in the compartment would be a 2s
e-mike
e-mike's Avatar
07.05.2008, 10:38 PM
im waiting for my e-revo...but im gonna put the 1515 1,5d in the revo...i have 2 8000mah maxamp..they will fit in the case of my revo????
azjc
07.05.2008, 11:18 PM
the biggest packs that will fit the stock compartments is 2s 8000 or 3s 5000
