Duster_360
07.05.2008, 12:01 PM
If the cells are not swollen, chances are they are fine. If you want to change wires, work on one wire at a time - less likely for a short to happen.
I would charge that pac outside too, but just the 1st time. If it's ok charging, then I wouldn't worry about the pac after that, just treat it like you do your others.
