novak 6.5 for crt.5?
Daddydancool
novak 6.5 for crt.5? - 07.04.2008, 11:05 PM
i am running with a 2s setup and a 16t pinion, i was planing runing a feigao 10t but i made a mistake and the one that i have is a 8t... and it's running hot in my t4 with a 20t, so I immagine it will run way too hot in crt.5,
is the novak 6.5motor a good idea?
kyosho501x
kyosho501x's Avatar
07.04.2008, 11:23 PM
won't it be a little too big? maybe you should get a feigao 7l
hyper 8- workin on conversion
Daddydancool
07.04.2008, 11:24 PM
well i was asking since i already have this motor
kyosho501x
kyosho501x's Avatar
07.04.2008, 11:26 PM
if if the novak fits try it.................
Daddydancool
07.04.2008, 11:30 PM
don't cost me any $$ to try it yes, i will have time to drive it only next monday, because i need to make a nice battery tray before runing it, i will post the updated result ;)
VintageMA
VintageMA's Avatar
07.05.2008, 06:52 PM
If you have the extended chassis the fit should be okay - could probably fit a 1515 in there.
“Everyone has a right to be stupid; some people just abuse the privilege.”
captain harlock
RC-Monster Captain
captain harlock's Avatar
07.05.2008, 06:59 PM
A 1515 Neu will easily fit in the ext. chassis. There is too much space for the motor, imho.
Nice to meet you!
Finnster
KillaHurtz
Finnster's Avatar
07.05.2008, 07:02 PM
I thought Go-Ride was using a 6.5R in his .5. Seemed to do well, but a bit underpowered IIRC. 35mph or so. This wasn't the RCM ext chassis tho.
I would try it, I would gear for 35 and see how it goes.
Daddydancool
07.05.2008, 09:47 PM
well i just got a novak 4300 at a cheap price on ebay, i will try both, and see which one is better for me ;)
VintageMA
VintageMA's Avatar
07.05.2008, 11:19 PM
My bad - I read a 6.5HV when you were talking about a regular 6.5R. Hmmm........ not sure that's going to be enough to push a CRT.5 - but others are using a CC 36xx motor with success - so it should work to some extent.
