skellyo
skellyo's Avatar
07.08.2008, 03:15 PM
Originally Posted by Superbasher View Post
Well so does a Rustler so nothing new there
It's quite a bit worse than a Rustler in terms of CG and traction rolling. I've got both and my Slash is on it's lid far more often with my moderately powered BL setup.
Superbasher
Superbasher's Avatar
07.08.2008, 03:29 PM
Fair enough, I just thought they were similair in terms of C of G.
  Send a message via MSN to Superbasher
rcsammy
buggy beater
rcsammy's Avatar
07.08.2008, 04:07 PM
iv run quite a few packs through it and yes it does roll alot easier than the rustler but you get used to the handling after a while and can easily drive it without rolling
i deffinatly want to get brushless
im still leaning towards the mamba 5700 at the moment though, mostly because its waterproof which means i can go to the track and it doesnt matter if theres puddles or its raining
edit: and thanks for the link to the manual :)
  Send a message via MSN to rcsammy
skellyo
skellyo's Avatar
07.08.2008, 05:45 PM
You can run the 5700 in there, but the 4600 motor is a little better suited for it IMO. It'll run in the low-mid 30mph range on 2S and if you want more speed, just drop in a 3S lipo.
rcsammy
buggy beater
rcsammy's Avatar
07.08.2008, 06:35 PM
would the 4600 give more torque then? being a lower Kv
and also run cooler?
