killjoyken
RC-Monkey Poo Flinger
killjoyken's Avatar
07.09.2008, 11:45 PM
you have to shave the fins down to fit inside the plastic housing its a tight fit but it works, and easier and better solution would be a FLM tranny case one of these days ill get one for my slash. i switched to mod1 gearing and can run 40/12 through 40/17 i usually run a 40/14 which is silly silly fast.
http://www.rc-monster.com/forum/atta...8&d=1214712244
Oooooo...that's what I was afraid of. I don't know if I'm willing to grind down my heatsink clamp or not. The FLM tranny is starting to look really good now.
I ran my Slash with 40/12 and a 2s lipo for a little up and down my street, but I'll have to wait to try it on 3s and check the temps.
Here's a pic of mod1 gears with the stock 48p spur on top and a mod0.8 (32p) spur for a Jato to the left. Revos use mod1 gears as well as all 1/8 scale buggies.
hailmick
07.10.2008, 03:34 AM
hay killjoy
can you still fit your spur /gear cover on that
if so is it modded
rcsammy
buggy beater
rcsammy's Avatar
07.10.2008, 06:08 AM
wow that looks alot better than the tiny teeth on the stock spur
and i have a load of spurs from my revo aswell
right i have some cash in paypal now so where can i get a 9L from as i cant fine one on mikes site?
and i will get some mod 1 pinions... how many sizes would i need to make sure i can get the correct gearing?
http://www.rc-monster.com/proddetail...=5mmmod1pinion
and will i need a bore reducer to fit the mod 1 pinions on the 9L?
http://www.rc-monster.com/proddetail...rod=RCMreducer
  Send a message via MSN to rcsammy
hailmick
07.10.2008, 07:11 AM
a 9l with 5mm shaft can be found here http://www.hobbycity.com/hobbycity/s...4&v=&sortlist=
but i have never gotten one from them i have a feigao one but id get this as the next best thing or 2 of them they are cheap you could try the 7L same kv as traxxas vxl motor and 9L the 4s champion at 60us for both its a steal plus delivery of course but youll still need monster mikes awesome mod 1 pinions
