rootar
rootar's Avatar
07.10.2008, 07:27 AM
usig the 9L on 3s start with a 40/13 and if your motor is getting hot and the esc alot lower try gearing up to a 40/14 but with either of these i think youll be more than happy as it will still pull a wheelie from 3/4 throttle roll.
and no the gear cover will not fit back on there, but as others told me its no big deal the mod1 gears spit out dirt like its nothing.
rcsammy
buggy beater
rcsammy's Avatar
07.10.2008, 07:39 AM
wow those motors are cheap
are they the same as the feigao 9L? they seem a but too cheap if you get what i mean
rootar why would gearing up make the motor run cooler?
edit: also what the difference between the different motors? like the 7,8,9 L, XL...
  Send a message via MSN to rcsammy
hailmick
07.10.2008, 07:47 AM
the differance in number eg 7 8 9L is kv the L motor 60 mm long the xl is 70 mm long the xL you can gear it up more and they tend to have lower kv which will produce less heat and they are cheap motor but if you do the right thing by them they will go great
rcsammy
buggy beater
rcsammy's Avatar
07.10.2008, 08:00 AM
ok then
so the 9L
http://www.hobbycity.com/hobbycity/s...hless_Inrunner
and while im ordering from hobbycity i might aswell try out a zippy lipo
either this:
https://www.hobbycity.com/hobbycity/...idProduct=6501
or this:
https://www.hobbycity.com/hobbycity/...idProduct=6350
i guess the zippy-H is the better pack?
and then a motor heatsink clamp and some mod1 pinions from mike
hailmick
just ive killed 2x 86 spurs vand a 20 and 24 pinion in two weeks i think ill be ordering mike mod 1s
sammy
the right gearing will keep the motor from over reving if im correct
