hailmick
07.10.2008, 07:47 AM
Originally Posted by rcsammy View Post
wow those motors are cheap
are they the same as the feigao 9L? they seem a but too cheap if you get what i mean
rootar why would gearing up make the motor run cooler?
edit: also what the difference between the different motors? like the 7,8,9 L, XL...
the differance in number eg 7 8 9L is kv the L motor 60 mm long the xl is 70 mm long the xL you can gear it up more and they tend to have lower kv which will produce less heat and they are cheap motor but if you do the right thing by them they will go great
rcsammy
buggy beater
rcsammy's Avatar
07.10.2008, 08:00 AM
ok then
so the 9L
http://www.hobbycity.com/hobbycity/s...hless_Inrunner
and while im ordering from hobbycity i might aswell try out a zippy lipo
either this:
https://www.hobbycity.com/hobbycity/...idProduct=6501
or this:
https://www.hobbycity.com/hobbycity/...idProduct=6350
i guess the zippy-H is the better pack?
and then a motor heatsink clamp and some mod1 pinions from mike
  Send a message via MSN to rcsammy
