chumanji
07.20.2008, 06:00 AM
Does anyone know...If this Hobbycity UBEC fails. Does it pass the entire voltage through like the CC or does it just cut the power?
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
07.20.2008, 12:05 PM
I'm not sure...mine's never failed. To be honest though, as long as you don't push it over its rated specs, then there's no reason why it should fail...especially with it having a thermal shutdown circuit. Like I say, I've been using one for about a year now with no problems whatsoever. I've also never had any noise problems either, though I'm on 2.4Ghz. If you're powering particularly expensive radio kit from it though, it's understandable to want to spend a bit more.
