lutach
lutach's Avatar
07.21.2008, 11:45 AM
Hey, do you feel like taking the endbell off and getting us a pic of the rotor and the windings? I would like to see what kind of magnet it uses...
Both the ones I have use one single magnet. It's a good thing to do is to open the motor and clean the magnet as I found some small peices of magnet stuck to the rotor. I might even go a bit crazy when the 2 correct motors comes in and wrap the magnet with either Kevlar, Carbon Fiber or some Spectra. The windings are basically the same as most Feigao and KD type motors.
07.21.2008, 01:17 PM
In that case, I doubt it will be much better than a feigao. It will disapate heat better, and the can will not come apart as easy. Those are reason enough to buy this over a smooth, pressed endbell feigao.
lutach
lutach's Avatar
07.21.2008, 01:29 PM
Yes, the extra material will help the motor with heat issues. The bad thing about the 45mm cans is that they won't fit my MBX5T. I'm afraid to try them in my BPP and the extra weight of the truck will probably be too much for the 1/8" shaft.
chumanji
07.21.2008, 01:42 PM
Can you post some pictures of the two ends of the motor? I would like to know how the endplates are bolted on.
07.21.2008, 02:16 PM
Assuming they are true clones, then the front is bolted on with 5 screws:
and 3 screws on the rear, spaced equally around the edge.
Getter Robo
RC Monster Fiberglass
Getter Robo's Avatar
07.21.2008, 01:55 PM
The shop also got motors which look just like the smooth can feigaos
Tesla 4 president!
